Activity Forums Compression Techniques compress for web – text breaks up during motion
  • compress for web – text breaks up during motion
    Posted by Rob Grauert on June 2, 2009 at 8:03 pm
    I am having a problem compressing a video for the web. The video looks great until the credits come onto the screen at the end.
    I am using Compressor to export a Quicktime with these settings:
    Codec: H.264
    FSP: 30
    Keyframes: Automatic
    Data rate: restricted to 775 kbits/sec
    Image size: 480X320
    I turn on frame controls, set everything to “Best” and I have it set to progressive scanning.
    The video originally had a black bar behind the text with 50% opacity, and I thought that was causing some problems when trying to compress. When I removed the black bar, the text still breaks up at the end.
    I have tried setting keyframes every 10 frames and every 30 frames, I’ve tried increasing the data rate, nothing seems to fix this problem.
    Anyone have any ideas?
    Here is a link to the video. Like I said, it’s the credits near the end that break up, the rest of the video comes out nice.
    https://www.robgrauert.com/sixminutespage.html
    Works best if you use Firefox or Safari. And you’ll need Quicktime player installed on your computer.
    Thanks for the help guys.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    Rob Grauert replied 17 years, 3 months ago 2 Members · 2 Replies
  • Daniel Low
    June 9, 2009 at 11:40 am
    Ummm, that’s a quite intesting type of breakup of the text.
    I suggest changing your keyframe setting to every 300 frames.
    Also, you have distorted the video by choosing a frame size that is neither 4:3 or 16:9 – what aspect ratio are you aiming at? It *has* to be one or the other, as it is, your circular medals are oval and everybody looks short and fat!
    See this to choose the right size:
    https://forums.creativecow.net/readpost/20/862224
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
  • Rob Grauert
    June 9, 2009 at 12:55 pm
    oh, you’re right. that flash calculator says it should be 480X360. I had 480X320.
    Thanks.
