Activity › Forums › Compression Techniques › Compress 4.5 K footage
  • Compress 4.5 K footage
    Posted by Dorian Weber on July 27, 2011 at 3:31 am
    I have been searching-and experimenting-for quite some time now… hope to find a solution here….
    For a project, I need to convert 4.5k footage (4480×1920) to a codec, a PC can read AND play. Meaning, the bitrate should be around 100 Mbps.
    I have tried TMPGEnc XPress, but unfortunately, it can read it, but not output higher than 4k. But I need the full Resolution.
    I have tried to transcode to MPEG-4 video, but the bitrate is still around 240 Mbps. If I set the “Limit Bit rate” lower, the quality suffers a lot.
    I am using a MAC Pro for output, but it has to be played on a PC.
    Dorian
    Craig Seeman replied 15 years, 2 months ago 2 Members · 1 Reply
