Activity Forums Apple Motion Compound shape/path
  • Compound shape/path
    Posted by Brendan Richards on October 14, 2010 at 7:34 pm
    I was hoping someone could help me with drawing a shape. I come from an Illustrator background and I am trying to draw what’s called a compound object in illustrator, but not sure how to go about it in motion. Specifically, I am trying to cut out the inside of an object, so that it is a compound shape, the inside not being filled. (an example would be a donut)
    Thanks for any assistance.
    Anders Larsen replied 15 years, 11 months ago 5 Members · 5 Replies
  • Mark Spencer
    October 14, 2010 at 7:53 pm
    Use a mask to cut out the inside shape
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Stephen Smith
    October 14, 2010 at 7:56 pm
    Brendan, please forgive me. I’m not an illustrator guy. So I hope this information is helpful:
    Create a shape such as a circle, go to the shape tab and uncheck fill and then check outline. Then you get a donut. Hope this is what you are looking for. Other wise you would need to create a mask or something. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Brendan Richards
    October 14, 2010 at 8:47 pm
    Thank you very much guys, since the thickness and shape of the object is irregular, the mask route is the way to go.
    Brendan
  • Zak Peric
    October 15, 2010 at 7:13 am
    Hi There,
    If you are working with Illustrator shapes then maybe you should look my tutorial about how to save custom shapes in Apple Motion. Maybe it will help you achieve what you want.
    https://embryo.me.uk/wp/2008/02/26/saving-custom-shapes-in-apple-motion/
  • Anders Larsen
    October 18, 2010 at 9:47 am
    As Mark said use a mask.
    Motion doesn’t allow compound paths in quite the same way Illustrator does.
    However you can achieve all the same effects by using multiple masks on the same object, and playing with the mask blend modes. It somewhat resembles the Pathfinder in Illustrator.
    Happy masking
