Activity Forums Maxon Cinema 4D Compound Paths
  • Compound Paths
    Posted by Adam Gagnon on March 29, 2009 at 5:34 pm
    First time with Cinema 4D, really any 3D package.
    The problem is I have a logo created in Illustrator that is made up of some compound paths (ie. O, A)
    The save the file as Illustrator 8 files import into Cinema 4D when I add the Extrude Nurbs all the compound paths fill in. The O doesn’t have the center part removed it’s all filled in.
    I’ve looked online for a solution with no luck.
    I’m just wondering the best way to deal with this problem.
    Adam Gagnon replied 17 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    March 29, 2009 at 8:47 pm
    select both splines in the ‘O’ (for example) and do a Functions/Connect. This will give you a new spline that contains both. Put that into the Extrude. The old splines will still be there, you can hide them or delete them.
  • Adam Gagnon
    March 29, 2009 at 8:52 pm
    Thank you so much.
