Activity › Forums › Adobe Illustrator › Compound path woes
  • Compound path woes
    Posted by Moog Gravett on June 9, 2015 at 10:31 am
    Hi guys,
    Hope you can help with something.
    I have a shape. Imagine a circle filled with stripes.
    This is created by making a stripe pattern and then using a circle as a clipping mask.
    What I want to do now is cut a square out of the stripey inside bit but I can’t make a compound object due to the clipping mask.
    Any ideas how I can cut a shape out of that?
    Moog
    Moog Gravett replied 11 years, 3 months ago 2 Members · 2 Replies
  • Jonathan Ziegler
    June 10, 2015 at 2:19 pm
    Sounds like you will need to release the clipping mask first, make your changes and then reapply the clipping mask. Please post your progress and any images you can. 🙂
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Moog Gravett
    June 10, 2015 at 2:24 pm
    Thanks for the advice!
    Somehow I managed to get it working … i’m still not entirely sure how 😉
    Thanks though,
    Moog
