Activity Forums Apple Final Cut Pro Compound Clips: Why doesn’t this work? Not understanding the workflow
  • Compound Clips: Why doesn’t this work? Not understanding the workflow
    Posted by David on July 13, 2011 at 2:30 pm
    So, I have three sync’d up scenes. (Yes, a dumbed down multicam). I compound them as one compound clip. I log the clip using markers. Now I would like to cut the compound clip into pieces and restore/expand the compound clip so I can access the three tracks (I know I shouldn’t use that word). When the compound clip expands I get the entire compound clip with no markers, not cuts.
    Clearly, I’m not getting something. Can anyone explain?
    Thanks, David.
    Noah Kadner replied 15 years, 1 month ago 3 Members · 2 Replies
  • Patrice Freymond
    July 13, 2011 at 4:08 pm
    when you cut the compound clip (I imagine you use blade for that), you effectively create 3 compound clips.
    If I understand what you want to do I think you must create the compound clip with all three cameras, open it in timeline first, and then add markers, blade the “tracks” and remove the unwanted parts.
    hope this helps and does not add to your confusion, guess we’re all a bit confused at the moment 😉
    patrice
  • Noah Kadner
    July 13, 2011 at 9:17 pm
    Yeah do the editing inside the compound clip, not outside. And remember you can create these right in the Event Browser, not just on a Project Timeline.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and GoPro HD Hero.
