Activity › Forums › Apple Final Cut Pro › Compound clips vs new Storylines- best uses for each
  • Compound clips vs new Storylines- best uses for each
    Posted by Jim Bachalo on June 18, 2014 at 8:56 pm
    When you need to group clips, which exist either as connected clips or in the main storyline, you have 2 main options
    1- compound clips
    2- secondary storylines
    Since both function to group clips, can anyone explain when you might use one over the other?
    You should follow me on Twitter here. My latest work
    Scott Witthaus replied 12 years, 3 months ago 2 Members · 1 Reply
  • Scott Witthaus
    June 20, 2014 at 12:03 pm
    I use compound clips to group “things” that I am “done with”. For example I was on a gig yesterday where the client wanted to use just certain parts of a music bed. I cut the song up to make it work, did the mix and was finished. For simple organization, I put all the music cuts into one compound clip. Same thing with various sound effects. Of course FCPX then creates a new clip in the event for each.
    Secondary story lines for me are a way to keep my options open when cutting cover footage and the like. I probably don’t use them as much as I should and need to learn more about using them.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
