Activity Forums Apple Final Cut Pro Compound clips effect on encode time
  • Compound clips effect on encode time
    Posted by Jim Waterwash on April 29, 2012 at 6:15 pm
    Hi, as my project with a duration of 5 minutes evolved, the encode times on my 2011 imac went from about 30 minutes to almost 3 hours in it’s final form. It’s a 1280×720 60p project that has the typical bunch of transitions between 4-5 second scenes.
    Is there any relationship between how projects get structured in FCPX and render times? Does the use of nested compound clips increase render time?
    At one point, I decided to wrap the entire timeline into a compound clip and named it audio, thinking that I could then place all my markers related to audio at that level. I felt forced to do that because I can only view the markers contained within a single compound clip and there is no way to categorize markers. This method of organization didn’t work out though, because if I then try to drill down into that compound clip, to actually fix the audio that might actually reside 3 nested levels deeper, the position of the playhead is lost as I drill down and I have to scub through to find my spot again. This makes no sense at all to me and assume it is a design bug.
    I’m curious of how other people organize their timelines to best make use of markers. Markers are powerful, but not having a way to both list all markers at all levels or to categorize their use (Audio,color,transition,etc), is very limiting.
    Jim Waterwash replied 14 years, 4 months ago 1 Member · 1 Reply
  • Jim Waterwash
    May 2, 2012 at 11:15 pm
    Not sure why it works this way, but I went through every compound clip that I had and turned off every possible adjustment (Color, Transform, Crop, Distort, etc) that might be causing the encode to re-encode. I also broke apart a clip that enclosed the entire 5 min sequence. My encode time dropped down to about 40 minutes from almost 3 hours before. I had made no modifications to any of these parameters, they were all in their initial states and even checked for any keyframes that might have been placed by accident. I had assumed FCPX would just ignore these when it came time to encode. I guess not..
    Call it a bug or just call it weird, but that’s how I fixed this problem.
