Activity › Forums › Apple Final Cut Pro › Compound Clip: Reference New Parent Clip is disabled
  • Compound Clip: Reference New Parent Clip is disabled
    Posted by Bill Rabkin on January 22, 2022 at 11:12 pm
    I have a custom lower third implemented as a compound clip. I need two of these in my project, so in the Browser I duplicate the original one. I know that both now refer to the same parent clip, so changing the text on either will change it in both.
    To overcome this, I select the second one (the duplicate) in the Browser or the Timeline. I then want to select Clip > Reference New Parent Clip, but that choice is disabled in the Clip menu. Why? How do I “divorce” the duplicate from the original, so that I can change them independently?
    I’d appreciate any suggestions.
    Bill Rabkin replied 4 years, 8 months ago 2 Members · 2 Replies
  • John Fishback
    January 23, 2022 at 3:02 am
    I think if you select the CC in the timeline, then > Reference New Parent Clip and the new CC appears in the Browser.
  • Bill Rabkin
    January 27, 2022 at 6:10 pm
    Thanks, John. That’s the way FCP is supposed to work, but unfortunately in my case when I copy a CC in the timeline, paste the copy elsewhere in the timeline, and then select the copy, one of two things happens:
    1. Clip > Reference New Parent Clip is disabled (greyed out) and cannot be selected, OR
    2. I click Clip > Reference New Parent Clip. FCP makes a new clip in the Browser, named “Oldname copy”. I modify the copy, which should have no effect on the original CC. However, when I then display the original CC it has the same modifications as the copy that supposedly has a new parent clip.
    I guess this is a bug in FCP, which I will report.
