Activity Forums Apple Final Cut Pro Compound clip reference audio
  • Compound clip reference audio
    Posted by Olly Bea on September 10, 2012 at 11:37 am
    Hey there, I have a slight issue, I wonder whether you guys could shine some light on it.
    I’ve just created a compound clip tidying up several elements, but when I dive in to do the more finer editing I lose the main soundtrack which is in the main project so I now can’t sync to this track without going back and forth. So my question is…. Is there a way to reference the main project’s soundtrack without actually ’embedding’ it within the compound clip (kind of like a guide layer in after effects)
    Does that make sense?
    Many thanks
    Olly
    Shay Carriere replied 12 years, 5 months ago 4 Members · 5 Replies
  • Kyle Bass
    September 10, 2012 at 4:30 pm
    Why not edit to the audio without using a compound clip and then compound it later?
    If you don’t want to do that, I can only think of one way and it’s not much more convenient. You could try using markers to show particular edit points of your audio within the compound clip.
  • Olly Bea
    September 10, 2012 at 4:41 pm
    I think just for good ‘house-keeping’ compound clips work well to keep everything tidy but I guess I could split them back up again re-time everything then compound clip them again… it’d just be real handy if there was a way round it.
  • John Davidson
    September 10, 2012 at 6:45 pm
    CMD-Shft-G on your compound clip, make come changes, and then option-g your clips back into a compound.
    It seems like a lot of effort but it’s really not a big deal unless you have effects on the compound clip too.
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Olly Bea
    September 11, 2012 at 8:28 am
    Yeah this seems like the best way to do it, thanks all
  • Shay Carriere
    April 1, 2014 at 1:47 pm
    I had a similar question about timing out bullet points with narration.
    I’m trying to use compound clips to contain the text and it would be nice if the playhead lined up ‘through’ a compound clip from where the playhead is in the main project, but it doesn’t seem to work this way.
    Is the ‘break apart clip items’ …adjust timing….then redo the compound clip method still the best way to go?
