Compound Clip and Slide Transition
Hey Everyone,
I keep running into different … what seem like … bugs in FCPX. Here’s one…
I’m trying to have a simple lower third come up and down from the bottom of the screen. So, I…
– Create a compound clip with nothing fancy inside – a clip, a simple title, and a shape (rectangle)
– Lay that compound clip on top of a simple a-roll clip
– Add the slide transition (a FCPX transition) to both ends
– Change “type” in slide properties to “Slide In” and “Down” (or any direction)Whenever I do this, on the outgoing transition, the whole clip comes down including the a-roll. I just want the compound clip to leave the frame.
Any ideas?
And…strike this whole post..I had the outgoing transition still set to “Slide In.” Grr.
Thx!
Jeff
