Activity Forums Adobe After Effects compositting shadows
  • compositting shadows
    Posted by Malcolm Desoto on February 23, 2012 at 8:13 pm
    I have a job coming up in which I’ll need to composite a full body actor into a different environment, upon which, they’ll have to walk around.
    Aside from matching perspective, I’ve always found getting the shadows right to be difficult.
    Usually, I motion track my actor into the scene, duplicate the layer, and then rotate the duplicate down on the X axis until the duplicate is under the actor to some extent. Tint the layer and blur it out a bit and you’ve made a fairly accurate shadow cast.
    The second step is to create a darker shadow under the actor’s feet by keyframing a mask around a black solid.
    This method has proved to work fairly well, but it is time consuming.
    I’m just curious if anyone has any preferred method or has seen a tutorial that may present an easier/more effective way to achieve this affect.
    Additionally, any notes on matching perspective would be appreciated as well.
    Currently, I just take notes on the camera’s angle, height and lens mm and then try to recreate that when I film other components of the scene.
    runawaykitee.blogspot.com
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Tudor “ted” jelescu replied 14 years, 7 months ago 2 Members · 1 Reply
