Activity Forums Adobe After Effects Composition nesting and sort of antialiasing
  • Composition nesting and sort of antialiasing
    Posted by Marcelo Terreni on April 27, 2006 at 2:42 pm
    Hi, I’m working with nested compositions on After Effects and I came across this particular problem. First, a link for you to visually check what is it all about:
    https://www.escuelasporlaidentidad.educ.ar/entrevistas/nesting.bmp
    In the first screenshot, we can see the composition “escena_02” used as my main composition (meaning I’ll get my final render from that compo). Although some scaling transforms were applied to still images on it , theres is no big difference from Photoshop originals. But then, we have the other case, the “main” composition, called “00_PRINCIPAL” wich includes “escena_02” as a layer (the way I should work on this project as I got several scenes), and there’s where the problema arrises. Notice the slight blurring on image definition produced by nesting while working on that “00_PRINCIPAL”. I wonder whether After Effects is applying some sort of pixel optimization, wich produces this unwanted loss of definition.
    The question is: is there any way to deactivate this sort of anti-aliasing applied to a composition when included inside another one? Could you imagine another workarround?
    Marcelo Terreni replied 20 years, 4 months ago 2 Members · 4 Replies
  • Michael Szalapski
    April 27, 2006 at 3:44 pm
    The picture doesn’t seem to be loading correctly.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Marcelo Terreni
    April 27, 2006 at 4:09 pm
  • Michael Szalapski
    April 29, 2006 at 10:03 pm
    I’m not sure why it’s doing that. Are your comps using the same pixel ratio? (Square pixels, etc.) Same comp size? Same frame rate? Same fields? If all these are right, I’m not sure what’s wrong.
    – The Great Szalam
  • Marcelo Terreni
    April 30, 2006 at 6:18 pm
    Thanks again Michael, this week I’ll be running some tests on the settings you’ve pointed out. Later I’ll post the results obtained.
    Marcelo
