Activity › Forums › Adobe After Effects › Composition > Make Movie LAGS!
  • Composition > Make Movie LAGS!
    Posted by Sam Garvin on September 8, 2008 at 8:27 pm
    I am somewhat of an amateur at Adobe After Effects. I have made a movie that I would like to be turned into the AVI format. I went to Composition > Make Movie, and waited the 5 hours that it took to render. Once done, the movie lagged, went faster then normal at some parts, and had no sound!! Please help!!
    Sam Garvin replied 18 years ago 2 Members · 2 Replies
  • Chris Wright
    September 8, 2008 at 10:09 pm
    picture of a speaker needs to be enabled in composition.
    output module audio output needs to be checkmarked and you probably exported an uncompressed movie which is more info than your hard drive can playback smoothly. try a DV video compression and see if that helps.
  • Sam Garvin
    September 8, 2008 at 10:30 pm
    Alright I will give that a try, thanks for your help.
