Activity Forums Adobe After Effects Compositing/aspect ratio/timelapse
  • Compositing/aspect ratio/timelapse
    Posted by Bipop Upreti on March 24, 2012 at 12:56 am
    Im have a shot from a CANON 5D shot at 1920 X 1080 30p, that was shot with the tripod locked in.
    I also have a a picture that is 2784 X1856 (3:2) aspect ratio.
    I need to composite these shots together but something about the aspect ratio is messing everything up. How would you go about matching the two stills, 1 that is 16:9 (1920 X 1080) and another 2784 X1856 (3:2), so they look identical?
    Right now when i scale the picture down to 1080 things look more squished than the still that is from the video.
    Here is the frame grab of the video shot at 1920 X1080 : https://imgur.com/rpGA2,4KmJJ#1
    here is the pic taken from the camera at 2784 X1856 (3:2) scaled down to 1920 X 1080. https://imgur.com/rpGA2,4KmJJ#0
    Notice the still is more squished.
    Bipop Upreti replied 14 years, 6 months ago 2 Members · 2 Replies
  • John Cuevas
    March 24, 2012 at 1:04 pm
    You don’t want to scale down your 2784×1856 to 1920×1080 because that is changing the ratio of the photo. Try using the fit to width command cntl+alt+shift+H. That will scale the picture down to 1920 but keep it’s aspect ratio the same.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Bipop Upreti
    March 25, 2012 at 3:19 pm
    Thank u
