Activity › Forums › Maxon Cinema 4D › compositing to AE
  • compositing to AE
    Posted by Jonas Espinoza on March 6, 2007 at 1:31 am
    have had troubles getting sittuated with the multipass workflow to AE
    -i have .b3d files turning up. most of the tutorials i have seen seem to skip through the details of multi-pass, and Im not sure in “multipass” how to set up so I have seperate image sequences for each channel I set up in the multi – pass section.
    Ideally I would have 8 or 16 bit tiff sequences of each channel.
    it seems like the .b3d file is a multi layer, but im not sure how to deal with it.
    – does multi pass render take multiple times longer, or is it just saving more data along the way?
    – is there any resources on good c4d to AE workflows.
    thanks
    Jonas Espinoza replied 19 years, 6 months ago 2 Members · 6 Replies
  • Mylenium
    March 6, 2007 at 9:53 am
    B3D files are bodypaint multi-layer files. They are useless for other programs. Render as PSD, TIF, RPF or each pass to a separate image sequence. Multipass rendering does not increase render time, it only dumps buffers to image files that the renderer generates anyways.
    Mylenium
    [Pour Myl
  • Jonas Espinoza
    March 7, 2007 at 1:07 am
    how do i set it up to be a seperate image sequence per channel/property?
  • Mylenium
    March 7, 2007 at 9:58 am
    Simply disable the “multilayer file” option on the mutipass panel. Then feel free to choose whatever format you deem suitable, but generally TIFFs and PSDs are the most reliable.
    Mylenium
    [Pour Myl
  • Jonas Espinoza
    March 7, 2007 at 8:55 pm
    will there be a name that associates the various image sequences with the channel that they are isolating?
  • Mylenium
    March 8, 2007 at 10:33 am
    Yes, each image sequence will get a prefix. The only inconvenience is taht C4D does not automatically organize them in sub-folders.
    Mylenium
    [Pour Myl
  • Jonas Espinoza
    March 8, 2007 at 4:38 pm
    thanks
