Activity Forums Adobe Premiere Pro Compositing question
  • Compositing question
    Posted by Paolo on October 8, 2005 at 9:02 pm
    Example:
    i want to make a zoom-out of the image, with a keyframe on the first frame of the clip and a keyframe on the last frame.
    If i go on the last frame, in the effect window, i don’t see the last frame of that clip but the first frame of the next clip.
    How can i set correctly the scale of the clip at that point if i cannot see his last frame?
    David Oulashian replied 20 years, 11 months ago 5 Members · 5 Replies
  • Larry Sherwood
    October 8, 2005 at 11:48 pm
    just use the left arrow key to step back one frame and create the effect, results will be as expected, if you like you can drag that keyframe to the end but results should be the same either way.
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
  • Paolo
    October 9, 2005 at 8:46 am
    This is the same strage beaviour of Premiere like when i go to an edit point, make IN, go to next edit point, make OUT, and make an Extract or Lift command.
    I want to simply select that clip and remove without use mouse but in this way it include the first frame of the next clip! I must every time remember to go left 1 frame and then make OUT.
    Maybe developers of PP don’t use so much the keyboard on editing…
  • Mike Velte
    October 9, 2005 at 11:48 am
    This is a bug I hope is fixed in the next version. Page down works fine, but End should go to the last frame of a clip, not the first frame of the next clip.
  • Steven L. gotz
    October 10, 2005 at 1:25 pm
    Mike, you may be right that End should go to the beginning of the last frame, as long as Page Down goes to the end of the last frame. It would make it a lot easier.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • David Oulashian
    October 10, 2005 at 6:15 pm
    Next edit in many editing apps goes to the beginning of the next clip. Then you simply step back on frame and mark your out point.
    It is this way in Avid and Liquid Blue among others. Not a flaw, just a design choice.
    David
