Activity Forums Maxon Cinema 4D Compositing Project File Crashes AE
  • Compositing Project File Crashes AE
    Posted by Bryan Rawles on January 18, 2008 at 1:18 am
    When I attempt to import a compositing project file into AE 7 it crashes AE. We are using C4d 10 with latest AEC plugin.
    The C4d project is 500 frames long, 1920X1080, has 3 lights and one camera, and 32 nulls with compositing tags.
    Reducing the number of frames does not have an effect, rendering 10 frames still crashes AE.
    Reducing 1280X720 does seem to help. Are we just maxing out the RAM?
    This is on macpro quad intel w/4 gigs ram.
    Thanks in advance.
    -Bryan
    Bryan Rawles replied 18 years, 8 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    January 18, 2008 at 1:54 am
    Sounds like a ram problem to me. I don’t know how the plugin works, but that’s a lot of data you’re dealing with. YOu might try saving out the AEC file without actually rendering. Hopefully that would bring in the 3D elements, allowing you to then bring in the footage manually. I can’t try it right now as I’m in the middle of a render.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Bryan Rawles
    January 18, 2008 at 2:24 am
    Thanks for the response.
    We tried bringing in the AEC file separate from the render with no success. We also made a separate project where we removed all the lights, took out half of the nulls, and exported the AEC file, still crashed AE on import.
    Can you import an AEC file without the associated rendered image sequence?
    -Bryan
  • Darby Edelen
    January 18, 2008 at 8:19 am
    I’m not a huge C4D guy, just getting into it, but I am an AE guy and I can tell you that AE 7.0 is not a Universal Binary and runs under emulation on an Intel Mac Pro. That would be my best guest as the culprit, do you have a copy of CS3 available to test with?
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Bryan Rawles
    January 18, 2008 at 5:06 pm
    We moved it over to CS3 and still crashing.
    Hey, we’re Santa Cruz too!
    Send me an email off list, like to find out what you do.
    bryan.rawles@gmail.com
