Activity Forums Adobe After Effects Compositing Plates? Example?
  • Compositing Plates? Example?
    Posted by Elliot Pollaro on January 23, 2010 at 6:49 pm
    I was wondering how you composite different plates together like in this video:
    https://vimeo.com/8882119
    If you go to 1:25 seconds in the video it will show the different plates and how that put it all together. What is this process. How is this done. Thanks!!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Maxime Marquis replied 16 years, 8 months ago 3 Members · 4 Replies
  • Todd Kopriva
    January 23, 2010 at 7:16 pm
    Here’s a basic summary of the tools and techniques used for compositing in general: “Compositing overview and resources”.
    The video that you linked to shows some good planning and technique, including getting good, locked-down shots of the background without the foreground items (the actors).
    Some basic rotoscoping was probably used to isolate the actors onto separate layers, and then those layers could just be stacked on top of each other.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Elliot Pollaro
    January 23, 2010 at 7:31 pm
    All of that was rotoscoped? I thought it could be but the people running in front of other people are CLEAN looking that some serious roto work
  • Todd Kopriva
    January 23, 2010 at 7:40 pm
    I can’t be sure, but that’s my guess.
  • Maxime Marquis
    January 23, 2010 at 9:21 pm
    Hi, Andrew Kramer made a tutorial that might interest you.
    https://www.videocopilot.net/tutorial/time_freeze/
    Hope this help!
    Max
