Activity Forums Adobe After Effects Compositing onto green screen, advice please
  • Compositing onto green screen, advice please
    Posted by Luke Tyrrell on July 28, 2013 at 11:40 pm
    Hi Guys,
    Wondering if I could get some advice. Basically I want to add footage on to the TV in the green screen shot and then ZOOM into the tv to display that footage full resolution.
    I’m struggling to firstly match the footage exactly up onto the TV due to its angle and secondly to get the camera to zoom in to show it full resolution..
    Any tips would be GREATLY appreciated.
    Thank You
    Luke Tyrrell replied 13 years, 1 month ago 3 Members · 4 Replies
  • Luke Tyrrell
    July 29, 2013 at 10:14 am
    Thanks i’ll give that a go!
  • Tudor “ted” jelescu
    July 29, 2013 at 11:54 am
    Is your Zoom done in production (real camera zoom) or are you planning to do it in post?
    If it’s a real camera zoom then Dave’s suggestion is the way to go.
    For a post production zoom you can work your way backwards- figure out how long you need the zoom to be (the longer it is the more you will notice degradation in the green screen plate). Go at the end of the zoom on the time line and scale up the image with the tv to fill the screen ( the whole tv screen, edges and all) and set keyframes. Use Corner Pin (under Distort) to match the screen with the video you want inserted and set keyframes. Parent the video layer to the green screen plate, go to the beginning of the timeline and scale that one back to 100%. Go back to the end of the zoom and scale the green screen plate a bit more until you loose the edge of the tv. If you need the video to be completely un-distorted then go 2-4 frames pass the end of the zoom and reset the corner control points for the Corner Pin to match the edges of the image to the edges of the comp. Add an Adjustment Layer on top with a animated Radial Blur (Zoom) to hide the image degradation and you’re all set.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Tim Parsons
    July 29, 2013 at 2:22 pm
    I have done this very thing in post using the corner pin method described above… be prepared for a major headache. corner pinning a frame so that an image within that frame (that has perspective distortion) becomes full screen… is no quick, fun task.
  • Luke Tyrrell
    August 2, 2013 at 7:31 pm
    Thanks for the replies guys. Really appreciate it! I got there in the end thanks to your instructions.
