Activity › Forums › Adobe After Effects › Compositing modes and why I can not get mine to work…
  • Compositing modes and why I can not get mine to work…
    Posted by Evideom on April 9, 2006 at 3:54 am
    I am messing around with the “modes” in After Effects and when I try to switch the mode on a layer, lets say to overlay, I see no difference in footage I am trying to combine. Why is that? I use Sony Vegas and when I try to combine layers using compositing modes it works fine, please help.
    Evideom replied 20 years, 5 months ago 2 Members · 2 Replies
  • Maurice Mahady
    April 9, 2006 at 6:02 am
    Is that because of opengl interpretation or lack of it? Try edit>prefs>previews>openglinfo and change quality drop down menu to “more accurate” alternately disbale opengl.
    This is what I recall from the text although my vid card radeon 600 displays belnding modes fine in default quality
  • Evideom
    April 9, 2006 at 11:12 pm
    Thank you so much maurice, that did the trick. It was my open GL setting, I had to switch it to “more accurate”.
    Thanks alot!
