Activity › Forums › Adobe Photoshop › Compositing in PS
Compositing in PS
Posted by Tod Geddes on January 25, 2016 at 8:48 pmI have a large number of Powerpoint “slides” individually saved (png) and need to make them usable in 16:9 videos.
Is there a way to import files(3:4)on to a new background (16:9), expand them to fit and save them? Preferably using a script or action.
Rudy Nooijen replied 10 years, 5 months ago 3 Members · 4 Replies -
Kalleheikki Kannisto
January 26, 2016 at 6:41 pmYes, you can do that with an action and a batch.
The how is covered here
https://helpx.adobe.com/photoshop/using/creating-actions.html
and here
https://helpx.adobe.com/photoshop/using/processing-batch-files.html#process_a_batch_of_files
Tod Geddes
January 26, 2016 at 8:01 pmThanks for the reply… guess I’m doing something wrong.
I have created a 16:9 black background, then I import the image and resize it to 1440×1080 then tell it to save and then remove that layer.I then go to automate and run the batch with that action and then it just goes through and creates files for the 1440×1080’s but no 16:9 background
I very rarely use scripts or actions… so not the brightest with them lol
January 28, 2016 at 5:11 pmIf you want to just stretch them to 16:9 (1920×1080), then you want to create an action that does that. Image>Image size… unlink the width and height and input 1902 pixels by 1080 pixels as the target size.
If you want to 1440×1080 plus have black bars on the sides, you want to increase the canvas size instead of the image size to 1920 by 1080 with you action.
Then batch your originals through that.
(Note: make sure you’re not saving over your originals by selecting a different folder to save the results in, rather than using the “save” command.)
Rudy Nooijen
April 10, 2016 at 4:50 pmopening a new file using a different pixel aspect ratio should fix it as well i guess
