Compositing in FCP… I know, I know…
First: I know I should be using AE or Motion. If I could, I would.
So I am creating a slideshow with multiple multi-layer PSDS in FCP. I am animating pretty much every layer of every image in the sequence, and am encountering some SEVERE problems.
It seems that images will arbitrarily stop letting me adjust their duration, in addition to not letting me add transitions after I have all the keyframing inside the psd done. I already changed my user pref for still to 1 minute.
Example: I put the psd on the timeline, blade it down to size, apply basic motion graphics to PSD. I then open the psd in the viewer to animate the individual layers seperately, so I blade down the “clips” to the approximate length that the psd clip is on the main timeline.
I then try to drop a transition between two of these psds, after animating all the layers. the transition will only take up one frame. It will not let me drag the transition length out. Then I try to change the duration of the PSD, figureing it has something to do with no having enough handle, and it will not let me change it at all.
Am I missing something? I know this is a terrible way to go about doing this, but its my only option at this point.
Thanks for any/all help guys!
Good Day
