Activity Forums Maxon Cinema 4D Compositing Green Screen Footage
  • Compositing Green Screen Footage
    Posted by Simon Matthews on September 14, 2012 at 11:56 am
    Hi, just a quick question. Can you import green screen footage into C4D and if so how is it done? Ie. I want to composite footage of myself into a project. The footage already has alpha channel. I know it could be done in After Effects but was just wondering if it could be done in C4D as well. Thanks 🙂
    Simon Matthews replied 14 years ago 2 Members · 2 Replies
  • Gene Strocco
    September 19, 2012 at 12:37 am
    Simon,
    You should be able to import green screen footage, whether its an image sequence or video file such as .MOV. You’ll need to create a new material and apply that as your color image.
    Unfortunately, the only way I’ve been able to use an alpha channel is if I either apply the same image sequence or video file as the alpha channel of the material, OR export a black and white image sequence/movie file and then import that separately into the alpha channel of the material you’re using.
    Then if you applied that material to a ‘card’ (or plane object), then it should render out as you want (alpha channel and all).
    Hope this helps.
    Gene.
  • Simon Matthews
    September 20, 2012 at 10:06 am
    Hi Gene,
    Thanks for replying. I’ve already tried applying the footage as my colour image and also applied it to the alpha channel but the result was a poor, ghost-like image. I see what you mean about importing it as a black and white sequence and I’ll give that a go next time to see if it works better.
    Thanks for your help,
    Simon.
