Activity Forums Adobe After Effects compositing based on Z depth
  • compositing based on Z depth
    Posted by Tomogomo on February 10, 2006 at 12:59 am
    Hi folks!
    – I have 2 clips with Z depth ( same 3D scene – diffrent objects )
    How i can comp them together using Z depth? …i badly need it that way there is some animated foliage and effects that need to be done in 3D before the second object .
    Same scene for both objects – i need the first one to overlap the second as if they were rendered same time.
    Please, guys…
    Tomogomo replied 20 years, 7 months ago 2 Members · 4 Replies
  • Chris Smith
    February 10, 2006 at 1:03 am
    Don’t quite understand. Why not just make the layer 3D and change the Z parameter to set them at different depths?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Chris Smith
    February 10, 2006 at 1:04 am
    Chris Smith
  • Chris Smith
    February 10, 2006 at 1:20 am
    Chris Smith
  • Tomogomo
    February 10, 2006 at 2:42 pm
    Hi
    I try to be more specific.
    There is a hill with animated foliage, on top of that hill there need to be some other stuff. I could use Z walue and 3D layers but what i have in mind is that this second object need to be placed AMONG the bushes and when camera is passing by it slowly reveals. I have Z channel within “hill” footage and i need the second object to be beetween certain Z values of the Hill’s Z channel so it can overlap and have rest of the hill’s Z values behind itself.
    In other words: Z channel is based on a grayscale and let’s say i want something to be placed based on this grayscale…something like compound Z channell…i don’t know…this is tricky for me
