Activity Forums Maxon Cinema 4D ‘Compositing Background’ weird issue
  • ‘Compositing Background’ weird issue
    Posted by Ryan Paterson on August 8, 2011 at 11:15 pm
    Im using the ‘infinite floor’ technique a la GSG, which basically means using a compositing tag with ‘Compositing Background’ checked. It looks great except that anything above the horizon line of the plane doesn’t show transparency, it just has a hard cutoff line along it. See attached image, near the top of the box the transparency just gets sliced.
    I understand why it happens, just wondering if there’s any way around it? Any help is much appreciated!
    Ryan Paterson replied 15 years ago 2 Members · 2 Replies
  • Henric Jentz
    August 9, 2011 at 6:31 pm
    Just replace the Sky object of the Seamless Floor with a large Sphere object. Apply the same material and the compositing tag to the sphere. Uncheck “Receive Shadows” and check “Compositing Background” in the compositing tag. This should do the job.
  • Ryan Paterson
    August 9, 2011 at 9:31 pm
    Yes, I figured it out actually- was using a Background object for the seamless floor but had a sky object in there as well, as soon as I got rid of that, problem solved.
