Activity Forums Adobe After Effects Compositing an energy ball to a footage
  • Compositing an energy ball to a footage
    Posted by Henrik Hansson on August 1, 2011 at 8:07 pm
    Hi I’m new here and I got a problem. I recently created an energy ball using AE. It’s called Rasengan by the way. But when I composite it to a background it loses a lot of detail. You can barely see it.
    Is there some effect or blending mode I should apply to get more detail? Thanks in advance!
    Brian Charles replied 15 years, 1 month ago 3 Members · 2 Replies
  • Joseph W. bourke
    August 1, 2011 at 8:37 pm
    Usually when I’m doing an effect which I want to look “hot”, as if it’s lit, or burning, I output the effect on a black solid background, and then composite it in AE using Additive mode. This mode adds the value of the bright pixels to those in back, making the back clip blow out toward white.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Brian Charles
    August 1, 2011 at 9:42 pm
    In addition to using additive blending modes you can use duplicates of the layer to increase pixel density.
