Activity › Forums › Adobe After Effects › Compositing an Alpha Channel Video
  • Compositing an Alpha Channel Video
    Posted by Alex Coulombe on December 24, 2008 at 5:00 am
    I’ve been struggling to get what I thought would be a very simple task to occur. I created a set of rendered frames with the alpha channels rendering as separate frames (because there’s no way to combine them in Maxwell Render). All that I want to do is bring the video of the alpha renders into the alpha channel of the main video (or rather, somehow, create a video with the transparency I need). I’ve tried a bunch of things in Premiere, After Effects, and even Photoshop all to no avail.
    Thanks in advance!
    Brendan Coots replied 17 years, 9 months ago 2 Members · 4 Replies
  • Brendan Coots
    December 24, 2008 at 7:15 am
    In After Effects, import both your animation and the alpha channel frame sequences. place the animation on a timeline with the alpha render above it. Every layer in After Effects has a pair of drop-downs, “Mode” and “Track Matte.” On your animation layer, set the track matte to “Alpha Matte *YOUR ALPHA LAYER*”
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Alex Coulombe
    December 24, 2008 at 12:51 pm
    Thanks so much Brendan! I got it to work, but for some reason not by setting the Alpha Video to an Alpha Matte. For some reason that made everything black. What did work (and I don’t really understand why) was setting the Alpha Video to a Luma Matte. Thanks again!
  • Alex Coulombe
    December 24, 2008 at 1:53 pm
    And for anyone else who runs into this, I also now know the same thing can be done with the Track Matte effect in Premiere, then references the Video Track that the Alpha Video is on. Hooray.
  • Brendan Coots
    December 25, 2008 at 3:55 pm
    Ah sorry, Luma Matte is indeed what I meant to say. Alpha Matte “borrows” the alpha channel from the layer above, Luma Matte uses the luminance.
    Glad it worked out!
    Brendan Coots
    Splitvision Digital
