Activity Forums Adobe After Effects Compositing Airplanes Question
  • Compositing Airplanes Question
    Posted by Alon David on January 11, 2016 at 10:56 pm
    Im a little new to after effects. I have a project where I want to composite airplanes in the sky. The planes would be from the pov of someone down below so the plane doesnt have to be detailed. I even have footage of a plane that I took in 4k at the park. How do I go about composting the plane onto a different sky. Should I make a freeze frame and composite the plane out and keyframe on a different sky? What is the most efficient way of doing this?
    Thanks in advance
    Stephen Smith replied 10 years, 7 months ago 3 Members · 2 Replies
  • Michael Szalapski
    January 13, 2016 at 10:52 pm
    Taking the plane out of a still and animating it yourself might work if you need to adjust the speed for some reason. However, the biggest concern is going to be getting your plane and your other footage at the same angle and with the same lighting. Nothing says “bad composite” like mismatched lighting.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Stephen Smith
    January 18, 2016 at 3:49 pm
    For fun you should check out Red Giants short film Go Bag:
    https://www.youtube.com/watch?v=r1g1Z9Da1Vc
    Here is a making of where they show compositing airplanes into the shots:
    https://www.youtube.com/watch?v=P7BaAIzSDCk
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
