Activity Forums VEGAS Pro Compositing
  • Compositing
    Posted by Pete Locascio on September 30, 2008 at 11:58 pm
    When green screening or sometimes trying to just superimpose a higher video track over a lower one, I seem to be getting a blend of the two tracks instead the higher track showing clearly over the lower track. What compositing mode should I be using and should there be a parent and child relationship between the two? Thanks!
    Danny Hays replied 17 years, 11 months ago 2 Members · 1 Reply
  • Danny Hays
    October 1, 2008 at 3:24 am
    I leave them in regular mode, and use the chromakey effect. Eyedrop the green and play with the faders until desired results are achieved. FYI, there is no spill supression in this plugin so put some space between the subject and the screen and uses some backlight to reduce spill. Hope this helps. Danny Hays
