Activity Forums Apple Final Cut Pro Legacy Composite with Alpha
  • Composite with Alpha
    Posted by Scott Sniffen on December 11, 2008 at 8:18 pm
    I have an animation as a separate clip. And a corresponding clip which contains the Alpha Channel. At the end of the clip, it is designed to reveal a new clip. What is the process to key the footage through so it reveals the end clip?
    Scott Sniffen
    Scott Sniffen replied 17 years, 8 months ago 2 Members · 2 Replies
  • Jamie Pickell
    December 11, 2008 at 8:41 pm
    Scott,
    Put your animation clip on video layer 2 or 3, then put your alpha channel clip on the layer below it, make sure they are in sync. Right-click on the animation clip and under composite mode select Travel Matte Luma. Your animation clip will read the luminance (i.e. the white to gray areas of your alpha clip) so that the animation can reveal video playing underneath.
    Jamie
    OS 10.5.5
    FCP 6.04
    Quad Core 3.2GHz
    8GB RAM
    XRaid
    Kona 3
  • Scott Sniffen
    December 11, 2008 at 8:58 pm
    Got it. The main problem was the clips I was working with were in the DV codec. Ugly and not supported for keying within FCP. Got it redone in Sorenson. Worked great.
    Scott
