Activity Forums Adobe Premiere Pro Composite Video Capture Card with Audio
  • Composite Video Capture Card with Audio
    Posted by Durwood Hibbard on October 12, 2015 at 12:51 am
    Greetings,
    I am trying to help out a local church with an issue. They had their video recording computer stolen and have since replaced it. However, they are in need of a capture card for there computer.
    They are dealing with SD video and need a composite input with standard (not optical) audio input.
    It has been a while since I Have been shopping for anything like this and would like some input as to what would be a good PCI capture card that could be used that is compatible with PP CS6?
    Thank you
    Yes, Yes I do realize I have no clue what I am saying.
    Durwood Hibbard replied 10 years, 11 months ago 5 Members · 5 Replies
  • Chris Wright
    October 12, 2015 at 2:23 am
    Adobe supports I/O cards from AJA, Blackmagic, Bluefish and Matrox and should be
    compatible with any OCHI-compliant capture cards.
  • Shane Ross
    October 12, 2015 at 6:13 am
    The current line of AJA cards don’t have component nor composite inputs. Only SDI. Best to look at Decklink options.
    Shane
    Little Frog Post
  • Kevin Rag
    October 12, 2015 at 7:13 am
  • Ann Bens
    October 12, 2015 at 10:18 am
    Get yourself a grass valley converter and firewire card.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Durwood Hibbard
    October 13, 2015 at 7:00 pm
    Thank you for the quick responses, Much appreciated. I will look into those options.
