Activity Forums Blackmagic Design Composite Output from DeckLink HD Extreme?
  • Composite Output from DeckLink HD Extreme?
    Posted by Steve Cohen on February 2, 2007 at 2:19 pm
    Basically the Subject says it all.
    I need to get a composite signal out of my DeckLink HD Extreme so I can make a VHS for a client.
    My component output is going to my LCD Monitor, I don’t have any decks connected that I can take a composite signal out of to feed the VHS.
    the only thing I have hooked up is a consumer Mini DV camera and an LCD monitor for visual reference.
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
    Chee Wee wee tan replied 19 years, 6 months ago 2 Members · 1 Reply
  • Chee Wee wee tan
    February 4, 2007 at 5:43 pm
    If you are lazy to unhook the COMPONENT then do following…
    1. If video is DV then: Firewire to DV camera -> DV Camera Composite -> VHS
    2. If video is SD then: Down convert to DV in FCP by nesting original edit into DV timeline, go to step 1.
    3. If video is HD then: Goto to step 2.
