Activity Forums Blackmagic Design Composite monitoring
  • Composite monitoring
    Posted by Richard Webb on May 3, 2005 at 10:45 am
    Hi all
    This is my first post so please be gentle! We just got our Decklink HD Pro on Friday so I’m still getting to grips with it. At the moment I’m cutting a project on FCP HD 4.5 in DVCPRO HD (shot on Varicam). My plan is to hire in a HD SDI monitor at the online stage so I can do colour correction etc, but right now it would really help to be able to use a domestic TV (with scart input) as a client monitor. Can anyone help me with what kind of cable I need and what settings I should make? Or is this not possible?
    Richard Webb
    Shotgun Productions
    London UK
    Richard Webb replied 21 years, 4 months ago 3 Members · 3 Replies
  • Boioboi
    May 3, 2005 at 11:11 am
    Hi Richard,
    I’m not exactly shure about the hd pro as I’m using DL Extreme, but probably it’s pretty the same. For analog output your possibilities are to go component (3 bnc-connectors) or composite (all information on 1 bnc connector). S-video isn’t possible. So probably you will have to use the composite output.
    additionally if your tv-set doesn’t have composite inputs (the yellow chinch connectors) you will need 2 cheap adapters. one which is bnc-male-2-chinch-male, and one chinch-2-scart.
    if you’re not shure which connector on your decklink is used for composite output, check out the connection-diagramm pdf which is downloadable at blackmagic-design’s website. if I remember correctly it should be the Y-connector. (There should be a option in your DL control panel to choose between Composite and Component Output, Sorry I’m on the Windows side, so I don’t know exacty where you have to look for at the mac…)
    I hope this makes sense to you…
    andreas
  • Craig Thomas
    May 9, 2005 at 4:07 am
    Not sure if you were asking about what type of consumer set to use.
    I just finished a job cutting with FCP and DVCPro HD 720p. I used a Sony wega XBR960 crt HD television. It worked great. It is by far the best consumer HD on the market. It cost about $1,900 USD.
    Hope this helps
  • Richard Webb
    May 9, 2005 at 2:04 pm
    Thanks guys
    I’ve come to the conclusion that the reason I can’t get it to work is that I’m using a standard PAL domestic TV (i.e. not an HD set – I’m not even sure you can get those in the UK). What I get is single frames (like you get when you don’t have All Frames set in External Video) but no moving picture. When I tried the same set-up with a DV-PAL sequence rather than a DVCPRO HD sequence it worked fine. So it’s HD on a normal TV that doesn’t work.
    Forgive me if you all knew that anyway.
    Richard Webb
    Shotgun Productions
    London UK
