Activity Forums VEGAS Pro Composeting mode!
  • Allan Boes
    July 24, 2011 at 1:42 pm
    No problem, just happy for the help 🙂
    Allan Boes!!!
    Working in Vegas pro 10
  • John Rofrano
    July 24, 2011 at 3:32 pm
    OK, you want to use Overlay mode and use Track Motion to size and position the frame. If you can see the square edges of the image, apply the Sony Levels plug-in to the image and adjust the Input End or Output Start parameter until the edges blend into the scene and disappear. You might even get it to match by adjusting the Gamma. The point is you want the gray to be exactly 128,128,128 so that it blends as neutral in Overlay mode.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    July 24, 2011 at 3:40 pm
    I’ve been following this discussion and am still puzzled as to why it’s not working properly.
    Allan, is it possible that you’re using the video previews and not the actual clips?
    I went to the web site for this product and here’s what they say about the product.
    Pre-Keyed Stock Footage:
    Built-In Alpha channels for faster compositing
    No complicated Keying with these clips! Just place an element over your footage and the background has built-in transparency.
    FORMAT INFORMATION: 2K & 720p
    Main Video Format: QuickTime RGB + Alpha, Video Codec: PNG
    Video Previews: QuickTime MP4, 480 x 360
  • John Rofrano
    July 24, 2011 at 3:55 pm
    [Mike Kujbida] “Pre-Keyed Stock Footage:
    Built-In Alpha channels for faster compositing”
    As you can see from the example, this particular effect does not have an alpha channel because it is meant to be used in Overlay mode where pure gray (128,128,128) would be invisible.
    ~jr
  • Allan Boes
    July 24, 2011 at 5:11 pm
    Now i’ve tried that and ended up with this picture??? Cracks looks fine ,but the rest off the picture????
    Allan Boes!!!
  • Allan Boes
    July 24, 2011 at 7:35 pm
    I’ve gotten it to work but you can see the edges of the image,I tried to use levels on it but that dont do the trick.
    Also the grafik aint that good,compared to the original, is that normal,it get kind of ruff in the pixels.
    Allan Boes!!!
  • Allan Boes
    July 24, 2011 at 10:35 pm
    Allan Boes!!!
  • John Rofrano
    July 25, 2011 at 3:17 am
    [Allan Boes] “Now i’ve tried that and ended up with this picture??? Cracks looks fine ,but the rest off the picture????”
    Did you use Pan/Crop or Track Motion. It looks like you may have used Pan/Crop. You need to use Track Motion.
    ~jr
  • John Rofrano
    July 25, 2011 at 3:21 am
    Without seeing everything that you are doing it’s hard to say. It looks like you may have added a Mask or Pan/Crop. If you did, try moving it to the end of the FX chain.
    ~jr
  • Allan Boes
    July 25, 2011 at 9:53 am
    I have just delete one of the images, and done it from scratch again with track motion.and used levels,but it’s the same.
    Here the process.
    1 Add image to screen.
    2 Change to overlay mode,place with track motion.
    3 set track properties.
    Properties:
    Video event: Loop on, maintain aspect ratio on
    Media : field order:none(progressive), pixel aspect 1000, Alpha channel none.
    That’s it, am i forgetting anything.
    Allan Boes!!!
Page 2 of 3
