Activity Forums Avid Media Composer Composer Window Zooming In
  • Composer Window Zooming In
    Posted by Daniel Flesher on July 28, 2015 at 7:53 pm
    Hello everyone,
    I have a basic question that I think is due to some setting that I have enabled / disabled.
    When I am in the Effects Editor the Source / Record windows are zoomed way in. If I start zooming out the image disappears completely and I have to enable the title safe bars to see where it is. When I use the hand tool (Control+Option) it only works when I am zoomed way into the image – as soon as I back out a little it stops functioning. When I exit the Effects Editor, the images return to normal size.
    Is there a way to center the image again so I can apply effects?
    Rob Wilson replied 10 years, 11 months ago 3 Members · 3 Replies
  • Shane Ross
    July 28, 2015 at 10:50 pm
    When you go into EFFECTS MODE, the controls that appear in the PROGRAM monitor include two magnifying glasses, one with a + and one with a -. Click on the “-” one to zoom out, and the “+” to zoom in…so I think you need to click the “+” a few times to get back in.
    Shane
    Little Frog Post
  • Daniel Flesher
    July 28, 2015 at 11:21 pm
    Sorry, I guess I’m not being clear enough.
    When I use the Magnifying Glasses to zoom either in or out, the image in the Composer Window glitches a little and repositions to the lower left corner of the image. However, I cannot see the image when I start zooming out and the only way for me to get a grasp of where it is is to enable the Title Safe lines.
    When I start zooming in I can only begin to center the image if I am about 3x zoomed into the frame (and it only zooms in or out at the lower left corner – even if I reposition the frame in closeup and start zooming out the image will snap back to the lower left corner and only zoom back from that perspective.)
    It’s a little vexing and my hunch is a tech glitch, but I’m wondering if this has happened to anyone else and if there is an easy remedy?
  • Rob Wilson
    October 16, 2015 at 6:37 pm
    I’m seeing this too. Did you ever get it resolved?
