Activity › Forums › Avid Media Composer › Composer Window Timecode Looks Squished!
Posted by Ivan Ivanov on November 17, 2014 at 12:01 amMichael Phillips replied 11 years, 10 months ago 3 Members · 5 Replies -
Michael Phillips
November 17, 2014 at 12:13 amThat represents a speed-up motion effect… 😉
Try resize your source/record monitor pane and see if that changes anything. If not, try some new user settings.
Michael
Ivan Ivanov
November 17, 2014 at 8:24 amI’m not sure how that represents a speed-up motion effect…
Re-sizing the composer window doesn’t affect the size of those little black boxes.
Try some user settings? I’ve played with the Bin, Composer, and Interface settings. Nothing. Any other ones I should try?? -
Ivan Ivanov
November 17, 2014 at 8:27 amI can change the font in my bins but when I select the Composer window and go to Edit=>Set Font… nothing happens. It’s not affected by it at all.
I’m starting to lose hope here… 🙁
Michael Phillips
November 17, 2014 at 1:51 pmApparently you missed the 😉 and the attempt at a joke (fast motion = squeezing more frames together in a shorter period of time…)
You could try deleting the MCState file at the program directory/settings level and let it rebuilt itself.
Michael
