Activity Forums Avid Media Composer composer monitor going black during playback of seq/clip
  • composer monitor going black during playback of seq/clip
    Posted by Obieobie on February 22, 2006 at 2:58 pm
    I transfered a project from my system @ work, and brought it home (using Avid Express Pro 4.6) Everything loaded ok, but when I put something in a SEQ, or play a clip in the preview monitor, the picture goes black. You hear the audio play fine, and when you stop the clip/SEQ the picture re appears in the correct spot. I can see picture is I scroll through a clip, or fast forward/rewind, but not during playback. My system at home, where this is happening is two days old, so it there a setting somewhere I may need to change in order to fix the problem?
    Obieobie replied 20 years, 7 months ago 1 Member · 1 Reply
  • Obieobie
    February 22, 2006 at 3:13 pm
    my graphics card is a Asus Ati Radeon AX1600 PRO, with 256MB DDR PCI Express. Is it possible I need to download a new driver that will handle that particular card? If so, where can I download the driver,
