Activity Forums Avid Media Composer Componet Input Issue (Xpress Pro + Mojo)
  • Componet Input Issue (Xpress Pro + Mojo)
    Posted by Martin Kraut on January 25, 2006 at 4:00 pm
    I have a new Mojo Box on our system and now the trouble begins.When i capture a clip from a beta-deck over the component input the signal looks like composite-Quality.I tried to measure my color setiings with the internal and an external vectorscope.The result was that the Y-signal from my Mojo Component out is 15 % lower as the incoming signal which comes from a testpattern generator.I modified my Proc-amps to the correct values ( Only Y to 1V ,Black to 0.3V and R-Y/B-Y ).Now the input and the output is equal.
    It means the looped signal from in to out is perfect.When I capture material with the uncompressed settings the picture-Quality is OK when I use the DV420-Format the signal lookes like a composite signal from a VHS-Tape.The video quality setting on my timeline is set to best Quality.At first i thought its a faulty mojo box.I tried the next one.Same problem as before but the Colour levels with this unit are only 5 % lower .The next test was to play out the material from beta to dv-device and re-capture this over the mojo firewire port.Voila the signal is ok Does that mean that the mojo box makes a poor A/D Conversion ?
    Any ideas ,has somebody the same issue ?
    Martin Kraut replied 20 years, 7 months ago 2 Members · 2 Replies
  • Ronen
    January 28, 2006 at 4:26 pm
    Did you import the test bars at 601 on the import settings?
  • Martin Kraut
    January 30, 2006 at 2:52 pm
    yes.
