Activity › Forums › Broadcasting › component to composite cable
  • component to composite cable
    Posted by Sam Lesante jr. on January 4, 2007 at 6:29 pm
    hi all,
    i was wondering if they made a wire that was the three component bnc into the one composite bnc.
    if not, what’s another solution?
    tia
    sam
    Peter Dewit replied 19 years, 8 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    January 4, 2007 at 7:33 pm
    Component will not “translate” to composite with just a cable.
    You need a “transcoder” that will convert the signals.
    However, if you have an “S-Video” output, you can simply combine the “Y” wire and the “C” wire together and it becomes a standard composite video signal.
  • Peter Dewit
    January 10, 2007 at 8:12 pm
    if you’re really desperate in a pinch you can loop the component signal through a deck. Just go component into the deck and take composite out the deck into whatever you’re dubbing to. This may not be as good as using a real trascoder and may require you to lock the video with a black burst generator.
