Activity › Forums › AJA Video Systems › Component Output 180º out on Capture
George Parker replied 17 years, 11 months ago 5 Members · 20 Replies
Gary Adcock
October 1, 2008 at 4:25 pm[George Parker] “But when ‘when’ capturing flesh colors are blue, greens are brown, etc. on the plasma”
so what do color bars via the kona Control panel look like?
if they are not correct – the plasma is connected incorrectly.take everything out of the loop first –
if using component
the KONA Control Panel / ANALOG OUT setting should be set on SMPTE EBU/N10 for video NOT RGB.All of your prefs were TRASHED when you installed the new software – you had something set up somewhere that is not standardized with other displays.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD -
Jeremy Garchow
October 1, 2008 at 4:35 pm[George Parker] “I wish it was that “easy””
🙂 You know, I remember something funyn about 23.98 captures and the Lhe. let me see what I can dig up. I thought it had to do with adding pulldown, but maybe not.
[George Parker] ” But when ‘when’ capturing flesh colors are blue, greens are brown, etc. on the plasma.”
This is in RGB mode? or SMPTE?
George Parker
October 2, 2008 at 11:12 amHey, Gary.
Color bars are fine. Everything is fine off the timeline and everything except footage that is 23.98 that is being captured is fine. If I put the analog out into SMPTE everything is green. It’s not a huge deal, ultimately, since it’s fine once it’s on the timeline. More curious than anything.
Geo
Jeremy Garchow
October 2, 2008 at 1:20 pmIs your monitor set to input RGB? It should be SMPTE if it is.
Jeremy
Slika Ton
October 16, 2008 at 7:56 pmHi George,
I just want to confirm that I’m having the same issue as you do. The only difference is I’m in Europe so I used the ProRes 25fps easy setup. And, yes, I did use an easy setup without changing anything. The image on MacPro screen is fine during capture, only component analog pass-thru on LHe gets shifted. Captured file is fine. I just cross the component cables on patch-bay during the capture as a workaround…
Slika & Ton
Jeremy Garchow
October 16, 2008 at 8:12 pmAfter capture, do you then swap the cables back? If this is so, I’d call AJA.
Jeremy
Slika Ton
October 16, 2008 at 11:07 pmHi Jeremy,
Thanks for asking, I do swap the cables back after the capture.
To tell you the truth, I’m from Serbia and swapping faulty card would be like 6 months endeavor here, so I just watch the vtr directly while capturing or go on a coffee-break.
I’m going to look at the captured material for couple of days during editing anyway so I don’t really need to babysit it during the capture. And captured files are perfectly fine. It may be just ProRes HD thing as I never had the issue with SD.
Slika&Ton
Jeremy Garchow
October 16, 2008 at 11:11 pmAt the very least, email AJA and tell them of your problem. Perhaps it’s something that can be fixed in software.
Jeremy
Slika Ton
October 16, 2008 at 11:19 pmYou are right, I should ask them about it by email… that is easy even from here…
Thank You
George Parker
October 17, 2008 at 5:46 pmOK. True once I changed my monitor to “component” instead of RGB then the SMPTE EBU/N10 setting on the AJA worked for everything except the same problem on 1080 23.98psf capture. So, I will query the folks at AJA. However, the last time a sent an email to support through their web support contact I heard nothing back.
Geo
