Activity › Forums › Blackmagic Design › Component out issues
  • Component out issues
    Posted by Chris Burke on March 8, 2008 at 6:46 pm
    I am trying to output video via the Decklink HD Pro DL PCIe version. I have downloaded the latest drivers and hooked up my Sony PVM-14N2U via the RGB cables. All I get are green squiggley lines. There is a bit of a picture in those green scan lines, but obviously not a usable one. I am not that familiar with the video nomenclature, but the BNC cables are labeled R-Y/R (I am assuming this is red), B-Y/B(blue?), Y/G (green?). I hooked the corresponding ends to the R,G and B plugs on the rear of the monitor. Lastly, there is a BNC cable labeled Reference In, I am assuming this is hooked up the the EXT SYNC plug on the back of the monitor. All I get are the green lines. Have I connected the cables incorrectly? I am able to connect one of the BNCs to a composite in and it works although it doesn’t look all that great. Lots of waviness and some scan lines, but an image. I really don’t think that it is the monitor, it has served me well before and gets a great image from the firewire out to a camera then out to S-Video. I am a bit concerned because there is rapidly closing window in which I must return the decklink card for a full refund. All cables are new. I am running FCS 2 (6.0.2). Please help!
    Chris Burke replied 18 years, 6 months ago 3 Members · 4 Replies
  • Chris Burke
    March 9, 2008 at 12:15 pm
    I have been able to get an image by setting the sync on my monitor to “sync on green”, but the image is all green. Any ideas?
  • Del Chapple
    March 10, 2008 at 6:48 pm
    hmm. rgb is different than y r-y b-y component.. are you able to get the composite output to work from the decklink to the monitor? I say lets start simple and see what works. I have a few sony crt’s that have bad component inputs, luckily they have two…
    d
    you cant hear my inner voice scream… can you..?
  • Kristian Lam
    March 11, 2008 at 6:42 am
    Hi Chris,
    Your monitor is expecting an RGB signal while the card is sending out a component Y,R-Y,B-Y signal which is why it’s not working. Some monitors have switchable RGB/Y,R-Y,B-Y inputs but it seems like the PVM-14N2U is not one of these monitors.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Burke
    March 11, 2008 at 10:58 pm
    that was the issue. thanks for the help
