Activity › Forums › Apple Final Cut Pro Legacy › Component into FCP
Component into FCP
Posted by Dan Davis on February 16, 2009 at 1:33 pmHi there,
Just a very quick one.
I have a client who has J3 digi player with component out (no SDI).
They want me to capture from this deck into fcp and do some reversions
to a broadcast programme. In the real world will component be good enough.Would be laying back sdi to digi in a post house.
Thanks for any advice.
Danny.Rafael Amador replied 17 years, 7 months ago 5 Members · 8 Replies -
Gary Adcock
February 16, 2009 at 2:13 pmSO what is your question?
HDSDI / SDI is a digital component with embedded audio and Metadata.
you loose nothing except connivence
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Rafael Amador
February 16, 2009 at 2:54 pmHi Danny,
With a good capture card will be no difference if you go Components or SDI.
Whichever the way you take, you need a capture card and capture 10b Unc or Proress.
Just need the correct easy setup.
Rafael -
Walter Biscardi
February 16, 2009 at 3:06 pm[Danny Davis] “In the real world will component be good enough. “
It’s been good enough for about 40 years now I believe. We run component out of our HDV decks and it’s good enough for HD Network Broadcast.
Get a Kona LHe and run Component directly in to your system. Or if you’re SDI input only, pick up an AJA HD10AVA converter to get an SDI stream out of that deck.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Gary Adcock
February 16, 2009 at 3:28 pmthis discussion is going on in two places
https://forums.creativecow.net/thread/98/872871
gary adcock
Studio37
Rafael Amador
February 16, 2009 at 4:19 pmRight. Going SDI you avoid the Digital> Analog> Digital conversion of the Components solution. However this “d> a> d” process done, as Gary points in the other threads, with an AJA or BM is virtually “lossless”.
Rafael -
Michael Allen
February 16, 2009 at 7:09 pmI have run into problems with the audio and video getting out of sync. when using the component in on my Kona LHe. Aja suggested a black burst generator to keep this from occuring. is this normal, does it ever happen to others using the aja card?
Mike
Rafael Amador
February 17, 2009 at 8:31 amWhen you work by component you need to keep in sync four different signals (Y’U’V’+Audio).
A symple difference in the length of the cables could cause a delay in any of them.
Rafael
