Activity › Forums › Adobe After Effects › compo and animation set up.
Posted by Benito Sanz on April 19, 2006 at 11:29 amhi all
Benito Sanz replied 20 years, 5 months ago 3 Members · 4 Replies -
Harryjf
April 19, 2006 at 2:00 pmThe perception of movement comes from the relative movement of one object to another… ie… one object is stationary, another moves, and we perceive motion because we have a frame of reference in the stationary object. This could be achieved with several objects, or a background, etc.
So, if your wipe is moving and the camera is moving with it.. what is providing your frame of reference?
Just a thought. Maybe I am way off as to what your problem is.
Benito Sanz
April 19, 2006 at 3:06 pmthanks the_harryjf, that’s exactly what i am trying to achive but i want it to do on a plain background and no stationary objetcs, i don’t know if there is a trick to do that???
thank for your replay again.
Jack Hilkewich
April 19, 2006 at 7:37 pmYou would need to add something to your BG in order to show movement. If you pan a camera around inside of a completely white sphere you would not have any sense of movement because the bg never changes. But if the sphere had a few splatters of red paint on it then you would see the red paint move past the lense. You need to give the eye a frame of reference.
So ad something to your BG some noise, scratches, color gradient, etc something to give the eye a sense of movement.
Benito Sanz
April 19, 2006 at 9:56 pmthanks shayder!
i gave it a try and looks much better. just one more question, i have a 3000×575 comp inside a 720×576 and the animation is long, is it better to use a much bigger comp something like 10000×576 or is it too much??? is it better to use diferent comps for a long animation,??? what way do you guys do it??
thanks a lot.
