Activity Forums Adobe After Effects Complicated Table Chart
  • Complicated Table Chart
    Posted by Elia Kremennoi on August 6, 2019 at 10:36 am
    Hello all.
    Got an interesting task and can’t figure out how to make it work in AE.
    What i can’t understand is how to achieve this: When green line moves up or down it has to become red and leave the static white line
    I used path, created nulls from it, assigned dots to each point and animated them.
    Thanks in advance.
    Graham Quince replied 7 years, 1 month ago 2 Members · 1 Reply
  • Graham Quince
    August 8, 2019 at 9:23 pm
    So you’ve done all the hard work. All you need to do now is use a duplicate of your green line layer as a track matte for another layer. I’d be tempted to create a pre-comp with the red and black areas and include the white line too. Then this layer will only be visible when exposed where the green line is.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
