Activity Forums Adobe After Effects Complicated Opacity/Random/Layers Expression Help.
  • Complicated Opacity/Random/Layers Expression Help.
    Posted by John Cuevas on February 6, 2007 at 4:54 pm
    Hi all, hoping someone might be able to help with this.
    I have a composition with 8 different color solids. Each solid layer is broken up into 24 square masks. These squares need to fade up(18 frames) hold for 1 second, then fade down(18 frames).
    What I need to happen is that the boxes will fade up, then fade down into different colors. I copied one of Mr. Ebberts expressions:
    A = 3;
    B = 7;
    C = 5;
    D = 11;
    f = Math.round(time/thisComp.frameDuration);
    t = 0;
    j = 0;
    while (f >= t){
    j++;
    seedRandom(j,true);
    period1 = Math.round(random(A,B));
    period2 = Math.round(random(C,D));
    t += period2 + period1 + 2
    if (f < t - (period2 + 2)){ 0 }else if (f < t - (period2 + 1)){ random(100) }else if (f < t - 1){ 100 }else{ random(100) } Using this expression + an expression on the actual layer opacity is very close, but these boxes flash way too fast & I don't have any clue how to change the parameters to what I need. Perhaps there is a much better way to approach this, but I'm not seeing it. Thanks Johnny Cuevas Ck&Co Media Productions Johnny Cuevas, Editor http://www.ckandco.net
    John Cuevas replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
