Activity Forums Maxon Cinema 4D Complex Vector/Spline Extrusion
  • Complex Vector/Spline Extrusion
    Posted by Ryan Paterson on November 15, 2010 at 11:45 pm
    I need to add some texture to a logo which is comprised of many overlapping concentric circles (182 of them to be exact). I need to make them 3-D but I dont want to connect/extrude them because the intricacies of the shape are lost this way. Ideally I would make each spline into a sort of tube shape so I can give them each a nice glass-like texture. Does anyone have any suggestions on how to do this?
    thanks in advance!
    Adam Trachtenberg replied 15 years, 9 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 16, 2010 at 12:50 am
    How does extruding them lose the intricacy of the shape?
  • Ryan Paterson
    November 16, 2010 at 10:37 pm
    It was just when I was using ‘connect’ the splines, they are tightly woven so it just didnt work. After that I tried the ‘hierarchical’ checkbox but it’s still not the look i’m after.
    Here is the main part of the logo-
    https://ryanjpaterson.com/ex/logo.png
    If anyone knows how to
    a) make each circle spline into a thin tube
    or
    b) Expand each one into z-space (like wrap them around a torus or something)
    That would be awesome!
  • Brian Jones
    November 17, 2010 at 1:18 am
    a) you could just Sweep a circle spline along your imported spline
    b) not sure I understand this, Rotate the circles so the whole logo is a torus and not flat?
    it also looks like it can be done with a single circle spline in a Mograph cloner set to radial except for the spaces on the left side…
  • Adam Trachtenberg
    November 17, 2010 at 4:55 am
    You can make each individual circle a tube by using the Structure>Edit Spline>Create Outline command and then sweeping the result.
