Activity › Forums › Adobe After Effects › Complex colour change (want to avoid rotoscoping if possible)
Peter O’connell replied 20 years, 3 months ago 5 Members · 12 Replies
X-claim
June 1, 2006 at 5:59 amThanks for having a play pete, that is pretty much the desired effect, this link is an example of how the roto version will look, still needs some edge tweaking(and this is just the first frame of about 250) and i’m going to have to pull some of the red out of the non green areas and skin tones to make it less contrasting.
https://img20.imageshack.us/img20/4195/greenwalltest0000305copy1pl.jpg
Peter O’connell
June 2, 2006 at 4:19 amI just thought I’d mention that you don’t need to roto really if you want to pull a key with a few choice effects.
If you are hell bent on rotoing though, go for it (don’t forget to track before you roto)Pete
Friday; June 2, 2006
12:18 AMbarxseven.com
