Activity Forums Adobe After Effects Expressions Complete Bouncing Parented Object
  • Complete Bouncing Parented Object
    Posted by Marcelo Cabral on May 29, 2020 at 7:48 pm
    Hi, I wonder if you can help me with this:
    I have one solid with keyframes in the position parameter.
    There is another solid in the same composition parent to the first one.
    What I need is the second objects have a bouncing effect on position, scale, and rotation (pendulum) depending only on the position movement of the first one.
    Thank you in advance for any help.
    Marcelo Cabral replied 6 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
