Activity Forums Adobe After Effects Comping Live Video in to CGI
  • Comping Live Video in to CGI
    Posted by Eric Kirk on December 9, 2010 at 7:09 pm
    Hello,
    This is just a rough still shot of a longer hallway that leads in to this chamber. I am trying to comp a live video of a guy walking through the doorway and having some difficulty in the workflow and wonder if someone could help.
    I can make a person walk up and down the hall all day long but when it comes to crossing the threshold of the doorway, for obvious reasons, I have difficulty.
    To do this, I shot myself on green screen, walking in the direction of the door, lifted my foot as if to step over in to the room and that is where I have my problem. Not quite sure how I place the layers so that it appears he has actually stepped through the doorway.
    I uploaded this file of a still shot. Hopefully it worked and appreciate the help ahead.
    1373_chamber.jpg.zip
    Eric
    Eric D. Kirk
    http://www.kirkproductions.com
    Eric Kirk replied 15 years, 9 months ago 2 Members · 11 Replies
  • 11 Replies
  • Eric Kirk
    December 9, 2010 at 7:39 pm
    Thanks for the quick reply.
    I’m tracking with everything you said I believe. So, just to get a little more info, it sounds like the key thing I was lacking is really just the green screen threshold?
    So, as I think through it in my head now, the exact matching of size, etc is basically so that the green screen would block out my foot at the appropriate spot where I pass over.
    Does that sound about right?
    Eric
    Eric D. Kirk
  • Kevin Camp
    December 9, 2010 at 7:58 pm
    i think you just need to do a split layer at the point where the subject appears to step though the doorway (edit>split layer)
    then you’d layer order the clips something like this:
    1. walking-down-the-hall layer
    2. the hallway layer
    3. walking though the doorway (split layer)
    4. back wall layer
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    December 9, 2010 at 7:59 pm
    then you’d order the layers something like this:
    4. back wall layer
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eric Kirk
    December 9, 2010 at 8:10 pm
    Appreciate it. I believe we are making progress. My next comment regarding the green screen threshold thought was that since it is just a few frames, I could mask the heel of the foot as it passes over to accomplish that.
    I like the sounds of this split layer idea though. I could use just a tad more explanation.
    I will just add comments to your 4 layers below and if you don’t mind…. 🙂
    1. walking-down-the-hall layer: Ok, this would be the layer of my actor (me actually) walking down the hall. Check.
    2. the hallway layer: Are you suggesting extracting the hall/cutting it away from the doorway layer?
    3. walking though the doorway (split layer): This would then be the same clip as number one but a copy as a new layer?
    4. back wall layer: Sort of same question as 2, are you suggesting I chop out the back wall that is visible through the main door?
    And then, a final question, when you say “Edit, split layer”, is that an actual command? (not at my work desk at moment to see in AE)
    Eric
    Eric D. Kirk
  • Kevin Camp
    December 9, 2010 at 8:38 pm
    [Eric Kirk] “2. the hallway layer: Are you suggesting extracting the hall/cutting it away from the doorway layer?”
    yep, the hallway (and doorway) would be separate from the back wall. there would be a hole in that doorway that you’d see though to the back wall.
    [Eric Kirk] “3. walking though the doorway (split layer): This would then be the same clip as number one but a copy as a new layer?”
    correct. using split layer it’s in point would be trimmed to start exactly where the end point was on the original layer… essentially the layer gets split into two layers, each getting trimmed to the current time indicator (cti).
    [Eric Kirk] “4. back wall layer: Sort of same question as 2, are you suggesting I chop out the back wall that is visible through the main door?”
    yes.
    [Eric Kirk] “when you say “Edit, split layer”, is that an actual command?”
    yep. choose edit (from the top menu bar) and select ‘split layer’ and it will split the currently selected layer at the cti.
    the idea is that you’d place the keyed clip over the scene, scrub though until you get to the point where is seems like the subject would be stepping though the main doorway, then do a split layer and move the new split layer below the open doorway layer so now it will be behind the doorway.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eric Kirk
    December 9, 2010 at 8:53 pm
    Kevin,
    Hey great run down on this procedure.
    It sounds relatively easy. This step below might have me a little. I mean, I understand how you say to do it, mentally, trying to understand what takes place here so that Layer 1 (the guy) appears to walk thru.
    Really appreciate your help.
    Eric
    Eric D. Kirk
  • Eric Kirk
    December 9, 2010 at 8:55 pm
    Dave,
    Thanks. Sounds like a I have a couple options to explore. I will first try the layering I think and see if that helps since it appears to have less to do with trying to perfect the size, etc as you mentioned.
    Shooting in HD, I typically end up reducing the size of my subject in AE.
    Eric
    Eric D. Kirk
  • Eric Kirk
    December 9, 2010 at 9:16 pm
    Dave,
    Sorry, that’s not what I meant. I have plenty of real estate with my wide angle Panasonic HMC150. Actually what I meant is I capture the entire figure but because I end up reducing the size while comping, it becomes of little importance then to have to worry about size perspective when I am inserting him in to the hall.
    So, I end up reducing the scale, maintaining the HD.
    Hope that was more clear. 🙂 But I will tuck your idea in my mind for later use. That is fantastic for close proximity shooting, like in my basement.
    Eric
    Eric D. Kirk
  • Eric Kirk
    December 9, 2010 at 9:27 pm
    Dave,
    Excellent point and fully understand. That really makes sense!
    Eric
    Eric D. Kirk
  • Kevin Camp
    December 9, 2010 at 10:03 pm
    so, you have a keyed clip of you walking away from the camera. when you drop that over your plate and scrub thru the timeline, at a certain point it will look like you should be walking thru the doorway, but you are still on top of the doorway…
    let’s just say at the 3 second point it looks like you should be walking thru the doorway.
    it’s at that point that you would split the clip layer. leave the first 3 seconds of the clip above the hallway/doorway plate, so it will look like you are in front of that plate.
    move the split portion (the clip from the 3 second mark on) to be bellow the doorway, but above the back wall. so as you play thru the timeline it will look like you move from in front of the doorway to behind the doorway at the 3 second mark.
    dave’s right about the set and the plate/virtual set… it will be tricky to get this to look correct perspective-wise. if that is important, you may want to try shooting your green with regularly spaced markers on the floor. you can then use those to help line up the perspective in the plate (this would most likely involve modifying the plate).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
